Brake noise
Old Jan 9, 2019 | 03:11 PM
Blaksilver's Avatar
Blaksilver
Default Brake noise
I just installed R1 concept crossed and drilled rotors. I put in brembo brakes. Why is it I hear a lot of squeaking? Should I just go back to oem rotors?
Old Jan 9, 2019 | 05:46 PM
waygreen's Avatar
waygreen
Do the pads call for a particular bed-in method?
Did you remember anti-squeal on the pads?
Old Jan 9, 2019 | 05:53 PM
Blaksilver's Avatar
Blaksilver
I did the bedding method.
Old Jan 9, 2019 | 06:56 PM
waygreen's Avatar
waygreen
Ok. Was it the method the pads called for or some sort of general method? I've had different pads instruct different speeds with different numbers of stops.
If you did use anti-squeal, did you use enough?
How agressive are the pads? Are they track pads, street pads or something in between?
You mentioned going back to the stock rotors. Did you previously run these pads on stock rotors without squealing?
Fife
Nov 9, 2014 05:33 AM
Jafch1
GX - 1st Gen (2003-2009)
Jul 1, 2013 07:22 PM
VIPNiSS
Aug 24, 2010 11:34 AM
gshb
Suspension and Brakes
Nov 19, 2007 10:56 AM
TwentyTen
Sep 21, 2005 01:15 PM
