Code po174
Old Jan 15, 2016 | 06:44 AM
BiggerOkie's Avatar
BiggerOkie
Default Code po174
Ok.........put the stones down,lol, no stones to be thrown because of the next sentence:
I used the Sea Foam "fogger" on the wifes RX and now I get the reoccurring: PO174 System Too Lean(Bank 2)
Ok, maybe I used bad judgement on the Seafoam. I haven't "searched" on here if many members are using the "fog" to clean upper cylinders, but I did and WOW....I killed a bunch of bugs. The EPA showed up at my door and told me that after they shut down all coal powered power plants, eliminate diesels, they are going to fine me $5 million for what I did to the environment.....
I am thinking after a good MAS cleaning this code might go away, but any thoughts or comments?
Thanks
Okie
Old Jan 15, 2016 | 07:09 PM
willhickey's Avatar
willhickey
you left the vacuum line loose or broke one
Old Jan 16, 2016 | 04:56 AM
BiggerOkie's Avatar
BiggerOkie
Thank you very much. Greatly appreciated
Old Jan 27, 2016 | 07:53 AM
burny's Avatar
burny
BuggerOkie, did it work?
Old Jan 27, 2016 | 11:17 AM
BiggerOkie's Avatar
BiggerOkie
Bugger, I like that. I might have to start using that one(l have lost 50lbs so maybe I am a bug and not bigger). I checked everything out and couldn't find any hoses off or loose. I had planned to clean the MAS(I hope I am spelling that correctly, MassAirflowSensor) but I erased it twice and it hasn't come back in. Only time will tell. I appreciate the help and replies. If it comes back in, I will post.
Thx again
BuggerOkie, shoot I mean BiggerOkie😉
Old Jul 13, 2016 | 06:42 PM
BiggerOkie's Avatar
BiggerOkie
It came back!
Old Aug 5, 2016 | 10:46 PM
BiggerOkie's Avatar
BiggerOkie
And came BACK in yesterday. I cleaned MAS, checked hoses, lines and everything associated with the intake. Any more suggestions?
Thx
freddiekd
GX - 1st Gen (2003-2009)
Jan 4, 2017 05:50 AM
diverchris
May 1, 2014 01:20 PM
ididit
RX - 1st Gen (1999-2003)
May 6, 2013 08:32 PM
kngkong
Maintenance
May 31, 2011 05:41 PM
Christian8
16
Nov 5, 2006 11:22 PM
