1998 GS400 Brake Fluid Amount / Volume
Old 02-10-03, 06:05 PM
///MDex
///MDex's Avatar
Question 1998 GS400 Brake Fluid Amount / Volume
I'm about to order my new fluid, and I don't have my OM with me.
How many quarts or liters does the system require after a full system bleed?
TIA
Old 02-11-03, 06:28 AM
BananaGS
Tech Guru
BananaGS's Avatar
hey Dex, I don't remember the OM states this info for the brake system, I would get 3 quarts to be sure.
Old 02-11-03, 10:10 AM
Mr Johnson
Mr Johnson's Avatar
Like he said. 2 will do but 3 to be safe. Once you open a bottle though throw it away. Don't hold it for use later.
Old 02-11-03, 10:15 AM
///MDex
///MDex's Avatar
Cool - 3 quarts it is - THANKS GUYS!
Old 02-11-03, 01:12 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
Mr J do you think that holds true for fluid you'd use in LSD as well? I bought some redline stuff for mine and they only had a gallon (takes about half to change). Does it go bad or is it just the brake fluid that has issues with exposure to air?
Old 02-12-03, 08:44 AM
Mr Johnson
Mr Johnson's Avatar
They are both hygroscopic (absorb moisture from the surroundings) but to different levels. Oils will have anti-emulsifiers added that minimize the hygroscopic actions but they will slowly absorb water too.
To be "safe" I wouldn't use either if they've been sitting for a while (say 6 months to a year) but if push came to shove I'd feel better about using the LSD oil than the brake fluid.
abs
05-03-19 09:15 PM
Gannet
09-19-12 10:13 AM
jeff1941
Wheels, Tires & Brakes Forum
21
02-28-08 11:29 AM
500amg
Maintenance
15
02-07-03 11:38 AM
lexie
09-17-02 11:43 AM
Quick Reply: 1998 GS400 Brake Fluid Amount / Volume
