Replacing Fuel Injector
Old Mar 8, 2012 | 06:59 AM
gindyo's Avatar
gindyo
Default Replacing Fuel Injector
Hi all, I am having a misfire in cyl. 6 I went through all the troubleshooting and found out that the resistance of that injector is 160ohms and the others are 14ohms. My question is can I just remove the front injector rail without touching the rear one?
Old Mar 8, 2012 | 07:26 AM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
Veteran: Army
Year make and model of car?
Old Mar 8, 2012 | 09:44 AM
gindyo's Avatar
gindyo
Sorry, it is a lexus es300 1998, but I already did it so never mind. It was really easy by the way. The only problem was when I was putting them back in. Instead of setting the injectors in the rail while it was out I put them first in the engine and them screwed the rail on top of them, which ruined the top o-ring of the injector.
Old Mar 14, 2012 | 06:15 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
always in the rail first, but even before you do that, a very light coat of new engine oil on the o-ring will enable it to slide in easily...
JustinCa65
Aug 13, 2018 02:07 PM
sdalton201
Jun 28, 2013 08:21 AM
renatodato
Jul 29, 2010 04:09 AM
archangels
RX - 1st Gen (1999-2003)
Apr 6, 2008 10:20 AM
