2000 Es 300 maintenance list
Old Apr 5, 2011 | 10:28 AM
windom619's Avatar
windom619
Default 2000 Es 300 maintenance list
Hello
My car is due for some major maintenance work. It's a 2000 and daily driven. Mileage is 160k. Brakes were just done. Local California car.
The things on mind to change out are:
-Timing belt
-All belts
-tune up (flush all fluids and sparks)
-O2 sensors ( code being thrown)
-water pump
-suspension (shocks and struts are done)
Is there anything else that I need to add/remove? Any recommendations on after market parts? Thanks.
Old Apr 5, 2011 | 03:12 PM
windom619's Avatar
windom619
Update
Thencode read now is P0446. The mechanic said it could be a variety of things relatednto thenemissions part of the car.. Any thoughts on what it could be?
Old Apr 5, 2011 | 10:28 PM
Vader300's Avatar
Vader300
Sounds like the evap system/charcoal canister? Could be the sloenoid. Id say go oem on t belt and belts, the suspension is probably the only thing Id go aftermarket.
Old Apr 8, 2011 | 05:10 PM
snowmaker's Avatar
snowmaker
Originally Posted by windom619
Hello
-Timing belt
-All belts
-water pump
Cam and crank seals. belt tensioner..Skip the 02 sensors unless (1) is throwing a code. Clean MAF and IVAC...PVC and grommet
Old Apr 9, 2011 | 10:16 AM
Vader300's Avatar
Vader300
He says he is getting a code for o2 sensor. Just swap it out. You'll get better mpgs and the code should go away
Old Apr 9, 2011 | 10:22 AM
snowmaker's Avatar
snowmaker
I agree swap out the bad one but do not change all the sensors here.
Klogan
Jul 26, 2019 03:12 AM
pittmanal
Dec 28, 2018 10:08 PM
Brandon593
Mar 11, 2015 11:00 AM
Lexusian
Nov 9, 2011 08:40 PM
blaktino47
Nov 12, 2010 01:56 PM
