Brake pad question
Old Feb 1, 2010 | 06:20 PM
tgcLS430's Avatar
tgcLS430
Default Brake pad question
Just replaced the brake pads at all four corners on my 2004 LS430 with 58k miles. The rotors showed no perceptable wear and do not show any signs of warping, so I did not replace them. The pad replacement was very easy, due in large part to the non-floating caliper design Lexus uses. One thing I noticed with the OEM replacement pads is they are tapered, such that the pad material area that contacts the rotor is less when they are new and increases over time as the pads wear. That is odd, as it seems like braking performance would be less when the pads are new due to decreased pad contact area with the rotor as compared with later in pad life when the pads are worn down and more pad area is exposed to the rotor. I did not notice any reduced braking effectiveness after installing the new pads compared with the old pads which were worn about 80%. Just seemed strange - anybody know why the OEM pads are tapered? I've replaced brakes on many of my vehicles in the past and never noticed the pads being tapered.
Old Feb 1, 2010 | 06:35 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
OEM pads are tapered to reduce dust accumulation.. this reduces noise.
ls1muscle
Suspension and Brakes
Sep 25, 2012 12:36 PM
mark98ls40
Oct 14, 2010 06:27 PM
tgcLS430
Feb 3, 2010 08:47 AM
933005spd
Jun 4, 2001 06:55 AM
