GS430 Servicing
Old Sep 13, 2008 | 12:08 PM
olemanGS's Avatar
olemanGS
Default GS430 Servicing
Im new to the website and just recently purchased a 2003 GS430 with approx 38k on it and have some questions....
1) When should I do a drain and fill to the coolant and ATF?
2) Thus far I have changed the oil, air filter and cabin filter is there any other recommendations?
3) I also noticed there is slight pull so I rotated the tires and it seem to pull more; my question is will a wheel alignment and wheel/tire balancing help the situation.
olemanGS
Old Sep 13, 2008 | 07:41 PM
PecosBill's Avatar
PecosBill
You shouldnt have to do anything to the coolant and trans for awhile. Did your GS come with a booklet containing info on when to do certain services at the right mileage?
As far as your pull, an alignment/balancing should sort that out.
Old Sep 14, 2008 | 07:49 PM
olemanGS's Avatar
olemanGS
Yes the car came with everything including the original window tag. From my reading up on these 30k servicings and others services they drain and fill the ATF also the coolant. With the services what is needed to do and what dont I have to do?
Old Sep 14, 2008 | 08:22 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
If its never been done, i would suggest a trans fluid and rear diff fluid drain and refill. Those are preventative maintenance items, and should help keep your car running good. As for the coolant, i would wait until the 60k service and do it then. The owners manual gives bare minimum recommendations, there are always going to be things that people recommend above and beyond the factory services.
And an alignment is probably what you'll need to get rid of the pulling. If the pulling changed by moving the tires around, then it could also been the tires causing the pull. I would check on the condition of the tires, and if you're due for new ones in the near future, then just wait and replace them and do an alignment at the same time. Saves time and money.
Old Sep 15, 2008 | 10:08 AM
olemanGS's Avatar
olemanGS
Ok, thank you.....Now what diff. fluid should I use? Is Mobil 75w-90 fully synthetic good??????
Old Sep 15, 2008 | 12:05 PM
RTIS250's Avatar
RTIS250
CL Folding 500,000
Any standard fluid will work good for you. Mobil syntethic is good too
mocanu
May 23, 2016 11:58 PM
Pakyaw
Jul 6, 2012 07:33 AM
NyCrAzY
RX - 1st Gen (1999-2003)
Jan 11, 2012 06:33 PM
WCF
Performance
Mar 1, 2008 06:34 PM
LEXman13
Maintenance
Nov 4, 2003 04:21 PM
