Transmission suggestions
Old Oct 3, 2006 | 02:22 PM
ISC400's Avatar
ISC400
Default Transmission suggestions
I have a SC400 which I will be installing a new dragon torque converter so while I was swapping the TC I was planning on changing from Toyota ATF fluid to AMSOIL synthetic ATF, changing the tranny filter and oil pan gasket anything else I should take care off?
And since I’m also supercharging my SC I’m planning on adding a tranny cooler would it be a hassle to add later or should I just install it now also?
How much is it tranny filter oil pan gasket @ the dealer?
How much ATF will I need?
Any recommended tranny cooler besides B&M?
Old Oct 21, 2006 | 09:56 PM
koolaidman's Avatar
koolaidman
since ur already there. replace the main seal
Old Oct 22, 2006 | 08:29 AM
mobilyte's Avatar
mobilyte
a341e tranny dry fill takes 8.7 quarts.
the filter is wire mesh and is easily cleaned, no need to replace unless it is damaged.
the gasket is fpig material, no paper/rubber gasket involved. you can pick up the gasket goop at any local parts store, just make sure you clean off the mating surfaces well before applying the sealant.
smerre01
RX - 1st Gen (1999-2003)
16
May 15, 2008 05:49 PM
rwheelz
Jul 4, 2007 05:44 PM
93SC300.
Jun 17, 2006 09:40 AM
additude
Maintenance
16
Aug 13, 2003 03:09 PM
lexian
Jun 28, 2002 11:56 AM
