Fuel Pump ECU which PIC?
Old Jul 8, 2006 | 02:13 PM
sahtt's Avatar
sahtt
Default Fuel Pump ECU which PIC?
O.L.T.'s post isn't showing up regarding it, probably because I am an idiot.
Which one is where I start thrashing to bypass the fuel pump ECU??
which is literally behind the seat or
which is bolted to the driver's side rear quarter panel. Much in that pic is to mov e the antenna. If anyone wants to point out exactly which connect and which side I'm going to wrecklessly cut, please do.
Thanks in advance,
Steve
Old Jul 16, 2006 | 10:27 AM
sahtt's Avatar
sahtt
Default Yep..
I know the answer is out there..
Old Jul 22, 2006 | 09:47 AM
Dx3's Avatar
Dx3
Steve,
Do you have an SC or an LS?? From your profile it appears you have an LS. The pictures OLT had posted were of the SC, so I am not sure if the Fuel Pump ECU is located in the same place on an LS. You may want to verify that first.
If you search my name and fuel pump in the SC section I am pretty sure I posted a really good link several years ago with a step by step guide on how to do it.
Good Luck,
Jonny
Old Jul 23, 2006 | 03:25 PM
Dramon's Avatar
Dramon
why are you bypassing it in the first place? If youre wiring it to run a constant 12v just get a 30a automotive relay and run your own wires.
pyr8
Dec 22, 2014 08:26 AM
dave_id
Oct 24, 2009 01:43 AM
LSing
Jan 6, 2008 06:24 PM
