Having starter problems?
Old Jun 14, 2006 | 12:02 PM
sockfocks's Avatar
sockfocks
Default Having starter problems?
My 1999 GS300 has 200,000 miles. The starter was acting up and would click a couple times before it would start. Well I thought the contacts were worn out and needed to be rotated or replaced because of the high mileage. I was dreading lifting up the car and removing the starter for fear of not being able to repair it and being out of a vehicle to drive. The starter finally wouldn't rotate anymore and would just click. A mechanic stopped and decided to help me. Appparently the problem was loose wire connections on the starter. He moved the wires in a clockwise direction to help tighten them and voila! no more dead starter!!! simply amazing. Its been about a month and the starter has been working just fine. Just thought I would give a suggestion to try.
Old Jun 14, 2006 | 03:36 PM
Tammy's Avatar
Tammy
May I suggest you disconnect the battery ground from the battery; for safety, and retighten the connections with a ratchet and socket.
I prefer the 3/8 inch drive ratchet for starter connections. Might start with a 12mm or 14mm socket size. You'll be tightening the highest current draw point in the auto electrical system, from the plus side of the battery. But there is plastic in the stud mounting, so be careful not too tight on the locking nut.
Loose connections or finger tight connections create high resistance points, electrically. Heat then develops and the connection tends to burn, ark.
With 200,000 miles, the starter motor brushes are probably worn away. You might want to locate a replacement and it's availability... as a standby.
Old Jun 15, 2006 | 07:32 AM
sockfocks's Avatar
sockfocks
Thanks and trust me, I would never put a wrench on a hot connection without disconnecting the ground first.
Old Jun 17, 2006 | 07:06 AM
koolaidman's Avatar
koolaidman
hahahh i always do. dont mind a lil bit of arc welding now and then
durring diag of the starter. that is 1 of the checks before condeming the starter.
MOAWINGS
Aug 26, 2020 04:19 PM
Alphaman19
May 21, 2014 08:09 AM
jerryparks
Aug 1, 2012 12:24 PM
OneJay
Aug 15, 2011 03:24 PM
b1gredek
Oct 7, 2004 08:45 AM
