Car is driving sloppy
Old Jun 13, 2006 | 10:12 PM
Xeeeeeem's Avatar
Xeeeeeem
Default Car is driving sloppy
Hey guys, i got a 95 gs300, with 106000. Seems like my car has lost power since i got her in september. It seems a lot more sluggish.
The transmission has gotten a lot more jerky
When i accelerate, it seems sluggish, right after it shifts, it doesn't have that constant power, it dips down in power.
Does anyone have a solution for these 2 problems??
(Things i've changed out: Spark plugs, tranny fluid, some gaskets, new cap, rotor,)
Old Jun 14, 2006 | 01:36 AM
cliffud's Avatar
cliffud
Former Vendor
maybe some sea foam is in order? i personally have never tried it but i've heard great things about it.
Old Jun 14, 2006 | 05:33 AM
fjurado1's Avatar
fjurado1
Did you change the tranny filter or just the fluid? Check the distributor cap, rotor and sparkplug wires. Those components can make a world of difference.
Old Jun 14, 2006 | 06:05 AM
Xeeeeeem's Avatar
Xeeeeeem
The tranny flush was done by kennedy transmission, so unless they were like jiffy lube in florida where they scam you, then i'd imagine everything was changed out properly!
Distributor cap and rotor were changed out, along wit iridium plugs, although the wires were not, and i know they are not in the greatest shape possible! I will be doing them along with my timing belt, water pump, and belt exchange. Could it just be the plug wires??
Old Jun 15, 2006 | 08:01 AM
Xeeeeeem's Avatar
Xeeeeeem
Could it be the cat back??
I just had my car checked out, i have a leak in my exhaust.....need to replace exhaust gasket
Old Jun 15, 2006 | 08:36 AM
Tammy's Avatar
Tammy
You could have the engine tested on a "Sun" style diagnostic machine. A good one will indicate if you have ignition, fuel supply, fuel injection or exhaust restriction problems.. along with which cylinders are failing.
Being in road salt country, could be a combination of the above. But the parts are too expensive to tackle it with a "twelve guage", meaning shotgun the problem by replacing parts..
Old Jun 15, 2006 | 08:55 AM
cliffud's Avatar
cliffud
Former Vendor
did the sluggish performance happen shortly after the tranny flush? mine performed a little slower after the tranny flush because all the crap inside started floating all over AFTER the new fluids were poured in... just a note- this is normal since the new tranny fluid is a lot more acidic than the old tranny fluid and so it breaks away chunks of carbon buildup.
For this reason, I've read that it's good to do a another flush a few weeks after your initial drain and refill but since you already did the flush - don't worry about it. i did the same as you, just did the flush and after a while, things were back to normal.
RepoRaf
GS - 1st Gen (1993-1997)
Aug 24, 2014 11:45 AM
Dltnjest
Oct 7, 2011 01:35 AM
Red Bully
Maintenance
Aug 26, 2008 04:47 PM
damon
Maintenance
Mar 26, 2008 06:28 PM
natedahms
Feb 16, 2008 09:30 PM
