a/c question
Old Jun 3, 2006 | 01:27 PM
1sxyrxy's Avatar
1sxyrxy
Default a/c question
i was charging my ac today because it didnt feal super cold to me so i discharged it then charged it and after that i took it for a spin. it was blowing nice and cool. so i pop my hood and look through the sight glass and there is nothing there. so i get back in the car and its still blowing cold jump out and look through the sight glass again and i could see bubles. the same as before i charged it then it went away. i havnt taked my ASE for AC yet but i thought looking through the sight glass your supposed to see a constant stream. also after all of it i noticed there are 2 low sides. whats up with that, am i supposed to do something special or use a certain low side to charge it with?
Old Jun 6, 2006 | 06:31 AM
jrmoskal's Avatar
jrmoskal
I am in the process of fixing the a/c on my 95 Sc3 also. I am a licensed ase ac tech and i have never seen a system set up quite like this one before. I am not sure about the 2 low side ports. i have used them both with equal results. I usually use the one towards the center of the inner fender. My car ended up having a small pinhole leak underneath the vehicle on the low side line near the drivers side. Whenever i would charge it up full after a few minutes there would be air in the sight glass due to the fact that the leak on the suction side of the system was drawing air into the system. I would check the lines carefully underneath the vehicle. they tend to rub on the brackets that secure them and over the years they will rub through and leak.
Old Jun 17, 2006 | 07:12 AM
koolaidman's Avatar
koolaidman
whats static pressure
whats the high side pressure
and low side.
by telling me that i can diag ur problem
crashman
May 23, 2017 04:51 PM
TLcoats
May 22, 2011 11:03 PM
mixmasterm
Apr 18, 2010 09:09 PM
maxgee
Jan 30, 2007 04:11 AM
