Clogged Winshield Washers
Old May 4, 2005 | 01:33 PM
vipermann1's Avatar
vipermann1
Default Clogged Winshield Washers
The washers on my 2002 LS430 are clogged.
Each nozzle has 3 holes.
On the drivers side only 1 out of 3 work
On the passenger side only 2 out of 3 work.
What should I use to clean out the nozzles?
Name of the chemical?
and also, how do i clean them out?
Do I use the chemical on the tips of the nozzles or put the chemical in the resivor tank.
Thanks.
Old May 4, 2005 | 02:59 PM
HarrierAWD's Avatar
HarrierAWD
They could be clogged by wax (did you wax the car lately?) In that case, use toothpick to clear the nozzles. Rub some dish detergent into the nozzles also helps since it can dissolve wax.
Old May 4, 2005 | 04:21 PM
vipermann1's Avatar
vipermann1
It's not wax. I am 100% sure of that.
The material seems very crust, almost crusty, but hard. and its inside the nozzle and on top of it.
Old May 4, 2005 | 07:03 PM
jdowen2's Avatar
jdowen2
Remove the washer nozzles and soak in vinegar.
Old May 4, 2005 | 07:09 PM
Exe's Avatar
Exe
This happened to my lexus too. I just took a sewing pin and worked them over a little. I should have done a better job though because now one of them sprays too high on the windshield.
Old May 4, 2005 | 08:17 PM
GS300Rich's Avatar
GS300Rich
If you stick a pin or something narrow enough to go into the hole you can aim each individual hole. I used the vinegar and water approach to unclog mine. It worked great
WISLUGGO
Automotive Care & Detailing
Aug 11, 2010 06:17 PM
TLe2006
Mar 31, 2008 12:42 PM
Budd28
16
Feb 14, 2007 03:08 PM
w84gdthng
Sep 23, 2004 02:10 PM
