remove driver side door panel
Old Nov 30, 2004 | 03:48 PM
tmyslivy's Avatar
tmyslivy
Default remove driver side door panel
My driver door no longer opens from the outside. I suspect the clip that connects to the rod has broken and fallen away. I can hear something rattle when I lower the window (which I will not do again until it is repaired). Can anyone give me the instructions on how to get the door panel off? Like what order to remove what so I can get it back together after I fix the clip? And if you have any other advice regarding the handle dilemma, that would be great. Thanks.
Old Nov 30, 2004 | 07:44 PM
lexusk8's Avatar
lexusk8
This question has come up many times before. Do a search for "door handle assembly" within the forums, and you should be able to find the answer.
While you're at it, I'm moving this thread to the Maintenance forum.
medlatawi
Aug 14, 2022 10:02 AM
BailsVT
Apr 29, 2014 12:30 PM
stat
Sep 17, 2011 07:05 PM
kphu
GX - 1st Gen (2003-2009)
16
May 26, 2008 07:47 AM
bpiatchek
Mar 17, 2008 08:02 PM
