How cheap can you get ????
Old Feb 4, 2004 | 07:17 PM
lexusguy's Avatar
lexusguy
Default How cheap can you get ????
Ok I know I will get flak over this but I am too cheap to pay the $132. Canadian (incl tax) for the cabin filter in my 93 LS 400 from the dealer. Maybe it's partly the principle of paying a rediculous sum for a plastic frame with a paper element in it. Has anyone cut out the paper and replaced it with another filtering medium such as a furnace filter ? I'm thinking of trying that route before shelling out the $ 132.00
Old Feb 4, 2004 | 08:10 PM
ls4oo218's Avatar
ls4oo218
hi i also have a ls 400 1993 and would like very much to no where it is located thanks for any help..
Old Feb 4, 2004 | 08:20 PM
gs400998's Avatar
gs400998
I buy the best 3M furnace filter and use it in my GS. I replaced it my 3M cabin filter every three months instead of Lexus cabin filter recommended every two years or 30,000 miles.
Old Feb 4, 2004 | 08:37 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
BananaGS has a DIY on his website how to do this. I'll find an link it in a sec.
Should be pretty much the same for LS and GS (except location)
Edit here it is http://lexusmodz.netfirms.com/GS_DIY/hepa_filter
Old Feb 5, 2004 | 05:43 AM
lexusguy's Avatar
lexusguy
Here is a link to a cabin filter change for the '93 LS 400. https://www.clublexus.com/forums/sho...t=cabin+filter
There is a lot of confusion as to where the filter is located. On a '93, you must remove the panel under the glove box (large plastic panel that slants downward and toward the engine) by gently prying it loose at the seam between the golve box door and the panel. Once you pop it loose, push it forward about an inch or less and it should release from the back. You can now get at the cover for the filters by taking off the two wing nuts you will see by looking up or using a mirror. Follow the instructions in the above link.
I am going to try the furnace filter replacement but I believe the 2 piece '93 filter may be too complex with it's necessity to bend it to get it into the housing. I may have to bite the bullet and get the rip off variety from the dealer.
Old Feb 5, 2004 | 08:02 PM
Lexkost's Avatar
Lexkost
You can make your own But the factory has charcoal in it for odors...................
StClair
Aug 5, 2018 06:06 PM
mistermet
May 30, 2015 01:02 PM
jscoda
May 29, 2015 06:24 PM
daryll40
Dec 2, 2008 05:13 AM
