Lexus IS 350 2008 Issues
Old Mar 16, 2025 | 08:43 PM
SultanKZ's Avatar
SultanKZ
5th Gear
Default Lexus IS 350 2008 Issues
Hi everyone,
This is a bit of a lengthy read, but I’ll try to keep it concise.
I have a 2008 Lexus IS350 that I bought as a gift for my brother, and it’s been quite the journey! Initially, everything seemed fine—the car passed all inspections with no apparent issues. However, just a week later, the car wouldn’t start. It made a slight clicking sound but wouldn’t crank or turn over. It would go into accessory mode, and the battery and fuel pump were both fine.
After some research, I learned about the fuel pressure sensor issue these cars are known for, so I replaced it, but that didn’t solve the problem. Frustrated, I took it to a mechanic, but they couldn’t figure it out either. Eventually, I brought it to Lexus.
At Lexus, after replacing the battery and the power supply ECU and running extensive diagnostics, they said they “traced a short to the power-on LIN circuit from the steering lock ECU.” They replaced the steering lock ECU but then found the short had fried the power supply ECU again. They assured me it wouldn’t happen again and replaced the power supply ECU for a second time.
Two months and $5,500 later—the car still doesn’t start. Lexus now says they need to do more diagnostics. While their repairs have fixed smaller issues (like door chimes and some electrical functionality), the main problem persists.
I’m now at a crossroads. I’ve already invested a lot into this car, and I’m wondering what to do next. I’ve found a mechanic who specializes in Japanese cars and electrical issues. Should I let Lexus continue working on it, or should I take it to this other mechanic?
Also, does anyone have any ideas about what might be causing this issue?
P.S. I’m in Ottawa.
Thanks in advance for your advice
