Hi I want to put 18inch wheels and tires on my 2018 lx 570 will it clear the brake and caliber assembly
the 18inch wheel is off my 2010 tundra can someone advise
Yes, no problems. I use 18" Tundra wheels with 275/65R18 Bridgestone Blizzak DMV2 for winter. I use Tundra alloy wheels but steel wheels are also fine.
Same here, but my wheels are Tundra steel oem.
My reason for choosing steel wheels were price...$200 for 4 with zero miles and TPMS ready to update with TIS. The price included Toyota lug nuts and hub caps...it all came off a new Tundra.
If you decide on steel, you'll need to increase lug nut torque to 148 ft./lb., and use conical lug nuts instead of those with a washer. Lugs may also take a different size socket, so be prepared. Keep a set of nuts for aluminum wheels in the truck if you have a flat and need to use the aluminum spare.
