LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
How to Reset the Range Function?
Old Aug 28, 2018 | 08:18 PM
Reggie1's Avatar
Reggie1
Default How to Reset the Range Function?
My 2013 when new would display ranges after fill-ups in the low 300 mile range. Over time the range after fill-ups kept getting lower and lower, and is now down to around 260 miles. To try to get better accuracy I have tried zeroing out every mileage function I can find, but still no luck.
Any suggestions?
Is there some hidden cumulative value that the vehicle uses? If so, maybe it's factoring all those trips in the past when I was towing a horse trailer. I use another truck for towing now, and would like to reset the Lexus so that the range starts out with a more realistic and current projection. My actual range is around 330 miles where and how I drive these days.
Old Aug 29, 2018 | 04:58 AM
hzhao's Avatar
hzhao
25 Year Member
Any suggestions?
Don't know if there is a specific procedures to actually reset range (I could be wrong). If I understood this correctly, the range is calculated based on last speed and fuel consumption samples. If I would stop at pump right off the freeway travel, it would result a higher range vs. if I went through a lots of traffic stops before arrived pump. One thing that you might want to try is drive the car to near empty, clear out all the data such as average fuel consumption, average speed traveled, etc., drive the car as you normally do for a short distance, then stop the pump and fill it up. Maybe that will give you a more accurate estimate.
Duonger
Feb 20, 2015 03:40 PM
SaintNexus
Nov 9, 2010 09:30 AM
sdpq
Mar 17, 2007 03:02 PM
Tmirk
Dec 3, 2006 01:33 AM
scottlx470
Sep 29, 2003 10:42 PM
