LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Confusion on purchasing 2009 LX570
Old 12-04-16, 04:11 AM
rishsngh
rishsngh's Avatar
Originally Posted by gfcipriani
I had this problem with a front leaky shock. The previous owner had the problem noted in the service record sense 80k miles and did not fix it; I purchased at 110k miles. I negotiated the price down and had the problem fixed at the dealership. May have been overkill, but I wanted to baseline the vehicle to ensure trouble free utility and peace of mind under my ownership.
Was it an expensive fix? What all did they do?
Thanks
Old 12-04-16, 11:42 AM
hankinid
hankinid's Avatar
Originally Posted by rishsngh
Should I continue with using it or get it fixed. It hardly looses 1 inch when turned of for a period of 3-4 days and fill back up as I drive it. I hope the pump for suspension is not over working?
One more time...
Have the pressure on each corner checked and recorded by somebody who knows what they're doing.
Hey! I don't understand. If it's hydraulic then and it leaks then I should atleast be able to see some sort of leak on the shocks or somewhere but I don't see anything?
Please help.
Do you see an oily coating on the lower portion of any of the 4 shock absorbers? Any leakage under or around the reservoir and pump?
Thanks
"Expensive" is relative. ;"
If the shock were leaking, they probably replaced the shock. That would / should have included bleeding and flushing the AHC system with new fluid.
Old 12-09-16, 05:22 AM
rishsngh
rishsngh's Avatar
Originally Posted by hankinid
One more time...
Will get it checked at a dealership. Hopefully it will resolve the issue. Thanks
Bobwplace
02-17-20 05:54 PM
insite4U
01-13-18 04:21 AM
waleedmm
10-05-17 06:11 AM
Hermes16
01-14-15 01:49 AM
Quick Reply: Confusion on purchasing 2009 LX570
