LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Automatic transmission fluid replacement lx 570
Old Feb 18, 2024 | 05:46 AM
RamonLx2013's Avatar
RamonLx2013
6th Gear
Default Automatic transmission fluid replacement lx 570
  1. Lift the vehicle. [*1]
    Note
    Set the vehicle on a lift so that the vehicle is kept level when it is lifted up (make sure that the tilt angle from the front to rear of the vehicle is within +/- 1°).
  2. Remove the No. 2 engine under cover and oil pan protector assembly.
  3. Remove the drain plug and gasket, and drain the ATF. [*2]
  4. Temporarily install the gasket and drain plug. [*3]
    Tech Tips
    Reuse the old gasket. The plug will be removed again to adjust the fluid level
  5. Remove the refill plug and overflow plug. [*4]
  6. Add fluid to the refill hole until it flows out of the overflow plug hole. [*5]
    Note
    Use Toyota Genuine ATF WS.
  7. Wait until the fluid flow slows and only drops come out. [*6]
  8. Temporarily install the gasket and overflow plug. [*7]
    Tech Tips
    Reuse the old gasket. The plug will be removed again to adjust the fluid level.
  9. Add fluid to the refill hole using the amount of fluid specified for removal and installation of the oil pan. [*8]
    Tech Tips
    Specified amount of fluid is 2.1 liters (2.2 US qts, 1.9 Imp. qts).
  10. Temporarily install the gasket and refill plug to avoid fluid spillage. [*9]
    Tech Tips
  11. Lower the vehicle. [*10]
  12. Start the engine. [*11]
    Note
    Make sure that the A/C switch is off.
  13. Slowly move the shift lever from P to S and then back to P. [*12]
  14. Allow the engine to idle for 30 seconds to warm it up. [*13]
  15. Turn the engine switch off. [*14]
  16. Repeat steps [*1] to [*14].
  17. Repeat steps [*1] to [*2].
  18. Install a new gasket and the drain plug.
    Torque:20 N*m { 204 kgf*cm, 15 ft.*lbf }
  19. Repeat steps [*4] to [*10].
  20. Adjust the fluid level Click here.
  21. Install the No. 2 engine under cover and oil pan protector assembly.
  22. Lower the vehicle.
  23. Operation complete.
2013FSport
Feb 15, 2022 03:06 PM
GR3Y5H3ART
Jun 30, 2021 02:45 PM
dreyfus
24
Sep 2, 2017 11:10 PM
ktmjay
RX - 1st Gen (1999-2003)
Oct 12, 2013 05:57 AM
ipwn
Nov 17, 2012 01:42 PM
