Speaker removal - 1997 LX450
Hi gang,
i need to remove/replace the drivers side door speaker. Does the speaker grill cover pop off
or do I need to pull the door panel off?
Thanks everyone.
Thanks everyone.
It's easy-peasy. Assuming you have a good set of panel removal tools you're 90% of the way there. Add a 10mm socket to remove the bolts along the bottom and a phillips screwdriver (though a real surgeon will have a set of JIS drivers) and you are ready to rock. Once you access the oem speaker and remove it, upgrading to a different speaker may require drilling a new mounting hole or 2.
hth
Thanks hankind. I do have all of those tools. When I started removing the panel, I noticed it was loose in one spot just in front of the speaker. When I pressed against the panel, the resonating noise disapppeared. Long story short, the speaker is fine - it was the loose panel resulting from a broken grommet causing the problem.
Found a replacement grommet in my medical kit and all is well.
Thnaks everyone.
Thnaks everyone.
Thnaks everyone.
Thnaks everyone.
oops. wrong thread
Shinchan
10-15-01 09:25 AM
