Help, Alarm goes off and wont start
When I press UNLOCK button on my key, the alarm goes off. The unlock/lock is working fine but I can't somehow turn off the alarm once it goes screaming.
The engine won't start either, every light indicators on my panel switches on but won't start.
When i insert my key, the red blinking car indicator turns off, so I thought it's not issue with immobilizer but not really sure. I've tried with my other master key SAME RESULT.
Following I've tried: Key programming which i've had to press pedal 5 times and brakes 6 times but it didn't solved my problem, the annoying alarm screams again.
I have a remote starter with unlock/lock button and the car starts fine. And when I put my key without pressing brake the car will move but again the alarm goes on.
Maybe i did the reprogramming procedure incorrectly. Where is the security light is located? Is it the red blinking dot or the red blinking car indicator?
It stated:
It stated:
OTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
KillerIzo
05-29-08 07:23 PM
