LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
upgrade to Lexus LX470 2003 or 2004
Old 12-02-07, 09:57 PM
m7tar
m7tar's Avatar
Arrow upgrade to Lexus LX470 2003 or 2004
Hi all,
I have Lexus LS430 UL 2002 with 95k
I want to upgrade to Lexus LX470 2003 or 2004
Is their any difference between Lx470 2003 or 2004
What are the options in LX470??
Thanks for Help (:
Old 12-03-07, 06:55 AM
V8_Fan
V8_Fan's Avatar
The '04 has the rear backup camera and, I think, gen-4 nav (I know the 04 landcruiser has the gen-4, but there were also nav unit issues on the LC...some failures, which cost $5K to replace). That's one thing I like about the gen-3 nav...tried and true, as it was used for several years prior. The transmission dipstick disappeared in '04, so if you ever plan to change your own transmission fluid, this would be an issue. The fluid type went from T-IV to WS (Toyota claims WS is good for 100K mi [no fluid is good that long]; you should probably change it more like 60K mi. '03 T-IV ATF should be changed at 30K intervals). Also, the '03 used the Toyota long life coolant (30K) while the '04 uses the super long life (100K mi). What all this means is that until about 90K mi, the '04 should have lower dealer maintenance costs at 30K & 60K miles.
It was either the '04 or '05 that has a lumbar support from the front passenger seat. This would be a nice feature to have. Otherwise, there is no quantum leap until '06 with the introduction of variable valve timing.
Old 12-03-07, 09:23 AM
m7tar
m7tar's Avatar
Post
Thanks a lot for replay
also I'm consider about the air suspension because I had several
issues in my LS430 UL
Old 12-03-07, 11:13 AM
lexusrott
lexusrott's Avatar
Originally Posted by m7tar
Hi all,
Thanks for Help (:
Access the lexus.com and look for the library , you can search previous year's options. This should help.
handogg
08-13-18 07:28 AM
Tomtieu
05-14-17 09:05 PM
Tomtieu
05-14-17 08:57 PM
lnguyenh
04-23-10 05:07 AM
Max707
06-17-07 09:24 PM
Quick Reply: upgrade to Lexus LX470 2003 or 2004
