LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Check Engine Light When Cold....
Old Feb 5, 2005 | 07:01 AM
Grd4Spd's Avatar
Grd4Spd
Default Check Engine Light When Cold....
hello all,
i had an issue with the check engine light coming on at startup.....however it only came on when outside temps get to the 10degree (or below) mark. when the light comes on, many times the car will not start or if it does it dies or not accelorate....sometimes or it will accelorate, then it will not.....revs do not come up, it stays at idol speed or dies, however sometimes it will run fine (with light on) just far enough to get into traffic then it will not rev/move or dies....if i turn it off sometimes it will not start again for a short spell....very strange...almost like the throttle is frozen? cold weather screwing with the efi computer? after it warms up it seems to work ok.......well as it turns out there were two error codes being tossed.....both pointing to the same thing
"Accelorator Position Sensor"
$350 for the part, $100 labor. gotta luv lexus.
regards,
terry
CheVelleSS
Dec 14, 2013 03:30 PM
ktboy
RX - 1st Gen (1999-2003)
Jan 3, 2004 04:11 AM
lexsc3
Jan 3, 2003 01:59 PM
palmerwmd
Maintenance
Oct 31, 2002 10:28 AM
