98-00 ls400 ocv filter change
Old Dec 15, 2013 | 05:29 PM
SynicalVip's Avatar
SynicalVip
Default 98-00 ls400 ocv filter change
Have anyone change out the oil control valve filter on the 98-00 LS400? I know and have read that people have clean them but I am in the process of doing the timing belt etc again and would like to change it
Old Dec 15, 2013 | 08:14 PM
billydpowe's Avatar
billydpowe
I have R&R mine and cleaned them and the chamber they go in.... BUT I have never changed the filter because you would have to remove the camshafts to do this... look under EM-28, page 1214 service manual 2000 LEXUS LS400..... or see attached ..good luck
Old Dec 15, 2013 | 08:30 PM
SynicalVip's Avatar
SynicalVip
Thanks for the diagram! I cleaned it but figure I want to change it since redoing timing belt and it was only like 8 bucks per filter
Old Dec 16, 2013 | 07:08 AM
billydpowe's Avatar
billydpowe
take photos and list everything that has to be removed to replace them... PD can make a sticky on them..
it looks terrible to me.
Old Sep 1, 2015 | 03:48 PM
TexusLS430's Avatar
TexusLS430
Did you ever replace your filters?
I am having a p1349 even after replacing the OCV solenoid. I am concerned that the filters might be clogged on my LS430 that I recently purchased. I haven't found much information as to where these filters are located, just that you have to remove the cams to remove them. I assume they can be accessed and cleaned but not removed, from the sounds of it. Whatever I can do to eliminate the need to replace the OCV controller itself. Holding off on a timing belt job until I can narrow this down.
Thanks in advance for any information you can provide.
Old Sep 1, 2015 | 08:05 PM
sha4000's Avatar
sha4000
This is on a LS 400.
Old Jun 18, 2017 | 08:45 PM
dashan's Avatar
dashan
Is this the view after you removed the valve cover? thanks
Old Jun 18, 2017 | 08:51 PM
dicer's Avatar
dicer
Obviously yes. And the front bearing cap.
Old Jun 18, 2017 | 09:07 PM
dashan's Avatar
dashan
Thanks. It will be a good practice to clean the OCV filter when replacing the valve cover gaskets.
Old Jun 19, 2017 | 08:50 AM
billydpowe's Avatar
billydpowe
Good idea, wish I had thought of it when I changed mine
gtoden1
Oct 1, 2009 12:17 PM
wqqclhtt
Jul 10, 2009 07:40 AM
DroppedGS
GS - 1st Gen (1993-1997)
Feb 9, 2004 05:04 PM
