Remove Maintenance Required message.
Old Sep 17, 2023 | 07:12 AM
sajack's Avatar
sajack
Default Remove Maintenance Required message.
I’m on a trip and “maintenance required “ shows up on my dash. I am due for L Certified free maintenance.
I intend to have that done when I return home.
Trouble is I can’t access the multifunction menu, that is : tire pressure, lane centering, steering assist, etc. because of the “Maintenance Required message.
is there any way I can remove this message so I can access the menu?
Old Sep 17, 2023 | 02:24 PM
PGA71's Avatar
PGA71
Try this:
Turn the ignition on.
Flip the odometer/trip display to “TRIP A” mode.
Switch the ignition off.
Hold down the “Trip Meter Reset” button while turning the ignition switch back on.
The maintenance light should blink, go solid, and then turn off.
Good Luck!
Old Sep 18, 2023 | 05:41 AM
Fhobbs's Avatar
Fhobbs
When mine does that, I press the return button on the top right of the controls on the steering wheel and it goes to the normal display.
Old Sep 18, 2023 | 06:18 AM
sajack's Avatar
sajack
Originally Posted by PGA71
Try this:
Good Luck!
I couldn’t get that to work.
sajack's Avatar
sajack
That worked! Thank you very much.
rdeete
Sep 15, 2017 10:01 AM
GSLexTexas
Apr 4, 2017 10:56 PM
admiral13
Jun 12, 2010 03:18 PM
lexusnc
GX - 1st Gen (2003-2009)
Aug 17, 2009 06:15 PM
Big Joe
May 31, 2009 10:12 PM
