LS460 AC diagnostic codes
B1495/95 - Rear exhaust mode damper position (for diffusion) does not change even if air conditioning amplifier operates rear exhaust mode damper servo motor
It's a damper motor, mounted on rear A/C unit. PM for pics if needed.
Would this cause the AC to not blow as cold?
It might. But I usually skip HVAC jobs so not very experienced. I've replaced rear blower motor once, an ordeal... But if you're small enough to fit into the trunk - it's not super hard as rear ac unit is attached to refrigerant lines via rubber hosing, so it wasn't necessary to evacuate/recharge.
userix
Aug 18, 2021 08:28 AM
jasone36
Mar 4, 2016 10:50 AM
