Lexus ls460 2009 AC control not working
2nd gear
My AC control unit is not working and not showing the temperature but shows passenger airbag on after installing carplay capability to the car. Also i ran out of battery while installing but was able to boost the car up. The ac control buttons also not working, I can increase or decrease the temperature but those on that control unit won’t respond, does anyone know what the issue may be?
2nd gear
It’s Grom Vline 2, followed the guide and instruction video to the letter, everything else is working fine, the system boots up with carplay and everything it’s just the temperature control display stopped displaying temperature and buttons above it stopped working. Should I check the voltage in the connector pins? Idk
Grom. is probably not the issue. When your battery went dead, it's possible that you blew a fuse for climate control. Not sure which fuse panel, owners manual should point you in right direction.
lexusguy83
LX - 3rd Gen (2008-2021)
12-19-20 12:57 PM
xe2000us
ES - 6th Gen (2013-2018)
05-22-17 10:37 PM
SC_Edgar
SC- 1st Gen (1992-2000)
12
07-25-09 01:15 PM
