awd suspension parts
Old Nov 16, 2021 | 06:06 PM
Jose201's Avatar
Jose201
10th Gear
Default awd suspension parts
Looking to convert a 2010 AWD LS from air to spirngs. Did research keep hearing of suncore,unity, and strutmasters.Definitely not going with the first 2, but has anyone tried the autozone duralast front struts($250each) or FCS struts(100$each) from partsgeek? I know fcs are usually cheapos but have no idea on the duralast.
Also which AWD front control arms are hardest to find or OEM only? Ive seen aftermarket front upper forwards for sure. Beck arnley makes front lower forwards(95995-05922634 partsgeek). They also make the front lower rearwards(95995-06002989 partsgeek). Couldn’t find front upper rearwards but is that it?
Old Nov 16, 2021 | 06:33 PM
Anfanger's Avatar
Anfanger
Go with OEM springs, you should be able to find everything you need on this website.
I am using Beck and Arnley lower forward arms, they seem to be OK. As far as I understand there is no aftermarket replacements for front lower rearward arms.
Actually, there are aftermarket replacements for front lower rearward arms. Thank you for sharing!
Old Nov 16, 2021 | 07:16 PM
erloco's Avatar
erloco
10th Gear
I Dont know about AWD, but, KYB Shocks worked really good on a 08 RWD. it didnt come w/Air Susp but the oem shocks were shot.
Aftermarket arms seems to work well.
Old Nov 18, 2021 | 12:18 PM
stopdrpnro's Avatar
stopdrpnro
ceika will do a set of adjustable coilovers for less than $1000. Just installed mine on my ls600 after they sat for a year and I'm upset i didn't make the switch sooner.
Old Nov 24, 2021 | 08:15 PM
Leximum's Avatar
Leximum
Default Air Suspension to Regular
You might want to try Fitment Industries....
fitmentindustries.com
I only looked at the website once and remember they do have a wide range of selections.
Old Feb 10, 2022 | 08:01 AM
DaSugarRay's Avatar
DaSugarRay
8th Gear
Was there any issue with the computer after you removed the Airstruts? Any DTCs? Did you removed the Air Compressor (pump) too? Im planning to change my Airs to Ceika coilovers too.
GrandSedanFan
Suspension
Jun 1, 2021 04:31 PM
Kennjo
Sep 7, 2020 10:13 PM
adamhaver
Jul 16, 2018 04:42 AM
vegasdave
Aug 11, 2017 05:38 PM
Answer
Suspension and Brakes
May 6, 2016 02:13 PM
