AFS system 07 ls460 base
Old Oct 27, 2021 | 12:22 PM
Smooth1ner's Avatar
Smooth1ner
Default AFS system 07 ls460 base
My AFS system has stopped working. I replaced my bulbs to see if that was the cause but no luck. Any suggestions on what it could be before i changed the afs module
Old Oct 28, 2021 | 04:13 PM
Thegamemhb's Avatar
Thegamemhb
Does it work when you turn the car on ?
​​​​what about the afs fuse and any work done recently on car ?
Old Oct 28, 2021 | 04:17 PM
Smooth1ner's Avatar
Smooth1ner
No and nothing but an oil change
Old Oct 28, 2021 | 04:22 PM
Thegamemhb's Avatar
Thegamemhb
And what about the switch is it blinking ?
did you try to reset the car by removing the battery ?
Old Oct 28, 2021 | 04:24 PM
Smooth1ner's Avatar
Smooth1ner
Yes the dash afs off light just blinks. And no. Just pull the positive well started right?
Old Oct 28, 2021 | 04:29 PM
Thegamemhb's Avatar
Thegamemhb
Ya better to pull the positive and see if works.
Is it just flashing on dash ?
What about the switch ?
Old Oct 31, 2021 | 02:23 PM
Parrokeete's Avatar
Parrokeete
my afs light came on my dash after my oil change. I wonder if that has something to do with it. The light is solid not blinking. During this same time my son used my car and set it to height high. I was looking at a YouTube video and saw where under the rear a bolt part was rusty and broke and might be the culprit. I’ll have to check it.
LS460AWDFS
May 2, 2024 12:40 AM
Dec 21, 2017 11:19 AM
LSF12
May 25, 2017 10:22 AM
amit1947
Jan 6, 2014 10:51 PM
GSsnarl
May 5, 2006 09:22 AM
