2013 LS460 clicking front left brake pads/caliber
Old Oct 22, 2021 | 08:13 AM
VAM1's Avatar
VAM1
Default 2013 LS460 clicking front left brake pads/caliber
I had replaced the front pads and rotors on my LS460 with factory parts. I had ordered the shim kit which I did not use as the shims appeared to be in good condition. I cleaned the pins and wire brushed the calipers where the pads would have a friction point. I also lubed the pins and the backs of the pads. The sound seems to be rotational in origin and occurs only when I depress the brake and is only coming from the drivers side. I do not believe that its the brake actuator. Any input would be appreciated.
Old Oct 22, 2021 | 08:33 AM
Anfanger's Avatar
Anfanger
There are also wire springs attached to pads to reduce rattle. Do you have those? When you installed the pads, did they slide easily into the calipers?
Old Oct 22, 2021 | 09:39 AM
VAM1's Avatar
VAM1
Yes the springs are in place. I do remember the Pads where a bit tight sliding.
Old Oct 28, 2021 | 06:51 AM
VAM1's Avatar
VAM1
Do you know if the pads should be snug or fit loosely when in the caliber? I plan on disassembling and replacing the shims and putting a new spring set. I can also lightly file down the contact points on the sides of the pads if needed.
Old Oct 28, 2021 | 07:35 AM
miket000's Avatar
miket000
The wire springs were worn on mine. I was able to reach in, with wheel on, and wiggle the brake pad. I think the springs can accidentally be installed on the top vs the bottom or vise versa. I don't recall which is correct.
Old Oct 28, 2021 | 07:38 AM
Anfanger's Avatar
Anfanger
After cleaning front calipers on my car from old grease, dirt and rust, pads went into in the calipers easily with piston completely depressed. I re-used old springs. I use 3M silicon for my brakes.
Mikey100
Aug 21, 2023 05:22 AM
hamooduae
Feb 15, 2022 11:20 AM
Gs46046
Jul 30, 2018 04:38 AM
fahq801
Apr 2, 2015 08:30 AM
hfahmy
Hybrid Technology
Aug 7, 2014 06:55 PM
