2007 LS 460 service 100k
Old Jan 5, 2021 | 09:01 AM
gwychejr1's Avatar
gwychejr1
Default 2007 LS 460 service 100k
I have a 2007 LS 460 with 99k miles, what is the cost of a 100k service? Also what's included with it?
Old Jan 5, 2021 | 10:06 AM
fwhomeboy's Avatar
fwhomeboy
https://www.google.com/url?sa=t&rct=...QP-yHIida7sEUE
Old Jan 5, 2021 | 10:11 AM
fwhomeboy's Avatar
fwhomeboy
https://redirect.viglink.com/?format...e%2FSedans.pdf
Old Jan 5, 2021 | 10:12 AM
fwhomeboy's Avatar
fwhomeboy
Read this too.
https://www.clublexus.com/forums/ls-...k-service.html
Old Jan 5, 2021 | 10:13 AM
fwhomeboy's Avatar
fwhomeboy
Service Notes per Owner's Manual
Engine Oil => Replace every 5K miles.
AC Filter => Replace every 10K miles.
Brake Fluid => Replace every 30K miles.
Engine Air Filter => Replace every 30K miles.
Spark Plugs => Replace every 60K miles required under the terms of the Emissions Control Warranty.
Engine Coolant => Replace at 100K miles; every 50K thereafter.
Transmission Oil => No need to replace since it's a sealed system.
So, at 90K miles you should be replacing the engine air filter, ac filter, brake fluid, engine oil/filter. If the spark plugs weren't changed at 60K, then replace now and then again after 60K miles.
Old Jan 5, 2021 | 10:58 AM
AZGS4's Avatar
AZGS4
You may want to read up on the transmission oil service. There are many threads on here recommending drain and fills regardless of the "lifetime" claim by Lexus USA.
Old Jan 6, 2021 | 03:16 PM
Caflashbob's Avatar
Caflashbob
Flush improved the trans smoothness
JDR76
Dec 14, 2022 10:28 AM
PeterLV
Wheels, Tires & Brakes Forum
Dec 7, 2020 03:00 AM
lexisnew
Jun 29, 2020 12:44 PM
