LS 460 A/C acts weird
Old Apr 17, 2020 | 08:05 AM
  #31
Originally Posted by Zammer
Am I reading the photo wrong, it looks to me that the amp (32) is right next to the air filter?
But it isn't visible without the glove box removed. That picture shows the glove box removed. This is what's visible when the filter is changed:
here's a video of the procedure:
Old Apr 17, 2020 | 08:26 AM
  #32
swfla's Avatar
swfla
Hoorah, a proper picture is worth a thousand words! Steve to the rescue. Again. Thank you.
Old Apr 17, 2020 | 04:41 PM
  #33
sha4000's Avatar
sha4000
I posted the Youtube video right above the pic of the AC amplifier in my earlier post which I guess the OP did not view. The ML amp is in the passenger quarter panel which the OP was talking about.
Old Apr 17, 2020 | 05:42 PM
  #34
swfla's Avatar
swfla
The picture of what would be exposed during a cabin filter change by the mechanic is the point I'm cheering about as the OP is confused on multiple things. He's also confusing ac amp with ML amp. It doesn't help that the ac control module is called an amp, it just lends to his confusion. Why is it called an amp as it doesn't amplify anything. That's rhetorical btw.
Old Oct 10, 2020 | 01:59 PM
  #35
Kingrb18's Avatar
Kingrb18
Originally Posted by sha4000
Is it because they don't want to warranty the service? Hold the BIG AUTO button and the recirculate button while starting the car and keep holding them until ALL the AC lights start to flash before letting them go. The display will give you 2 digit codes if anything is wrong with the servos. 00 means everything is working properly. You can ignore 21 24 and 28 because they are solar sensor codes and if you run the test when it's dark it sets them off.
Mine is showing 41. Do you know what code is this?
Vansibel
Hybrid Technology
Jan 28, 2015 05:51 AM
dotbowels
RX - 3rd Gen (2010-2015)
Dec 29, 2014 09:52 AM
rohanstar
May 1, 2014 11:59 AM
Patsum
Aug 11, 2012 03:11 PM
jmscott
Oct 17, 2010 10:02 PM
