2010 LS460 110v info
Old Nov 22, 2019 | 06:23 PM
CmorButts's Avatar
CmorButts
Default 2010 LS460 110v info
Hi All,
My 2010 Ls460 has the 110v/120w AC power outlet in the rear console and I am unable to find any info on it.
Moreover I'm looking if it is possible to change it from 110v to 220v. Does anyone know if its just a DC to AC convertor that can be replaced or is it more complicated?
Regards,
Chris
Old Nov 22, 2019 | 06:57 PM
DerrickM's Avatar
DerrickM
Um, I just have to ask why you want a 220 volt outlet inside your car! I'm thinking about what in my house uses 220V, and I'm thinking oven, cooktop, clothes dryer, and shop heater...
Old Nov 22, 2019 | 07:36 PM
CmorButts's Avatar
CmorButts
I live in New Zealand. Everything is 220v. The only thing I could run off 110 is a shaver or a phone charger and this also has the "lighter" socket and USB inside the concole so phone charging not an issue.
Old Nov 22, 2019 | 07:46 PM
DerrickM's Avatar
DerrickM
Oh, that's funny. Sorry, I didn't mean to be rude.
Is there a commonly available device to convert 100v to 220v? Like something you just plug in that has a step up transformer inside it?
Old Nov 22, 2019 | 08:20 PM
CmorButts's Avatar
CmorButts
Yes there is but they are well over 120w and would blow the fuse I believe. I was hoping it was just a DC to AC converter I could swap out.
Old Nov 23, 2019 | 05:07 AM
Dave144239's Avatar
Dave144239
You might find it in other markets that use 220V, https://www.worldstandards.eu/electr...ge-by-country/
I have a 110V to 220V transformer I bought for old stereo equipment, and as you said, it draws a lot of amps. It also doesn't convert 60Hz to 50Hz, so it was useless as a power source for my old turntable (records spun at 40rpm instead of 33.3rpm).
Old Nov 26, 2019 | 04:39 AM
MacroP's Avatar
MacroP
Would be intereted to see pics. Never knew they has these on some spec ls460s.
Just to let you know that current series Prados (2009+) have a 230V 100W outlet (AU/NZ spec 3pin outlet) in the rear cargo area on right side - It comes in handy sometimes. There's an inverter module behind the outlet. I do wonder if the module and outlet are transferable to the LS?. Would be plenty of Prados at the wreckers/salvage yards around NZ I would have thought.
PlatES300
Aug 27, 2016 10:38 AM
Skillet64
Feb 2, 2014 08:42 AM
tank97
CT 200h Model (2011-2017)
Jun 24, 2013 11:56 AM
ikeb
Feb 17, 2011 05:15 PM
LuvLuxury
Apr 30, 2009 11:17 AM
