19 inch wheels
Old Oct 31, 2019 | 06:58 PM
Spudo769's Avatar
Spudo769
Default 19 inch wheels
Looking at a newer LS, a 12 vs my 07. The 12 has optional 19 inch wheels. I have 18's on the 07. I have 18 inch wheels and winter tires. What would happen if I swapped the 19's for the 18's in the winter? Do they calibrate the speedometer when they put the 19's on?
Old Oct 31, 2019 | 07:23 PM
rogersmj's Avatar
rogersmj
There's no calibrating the speedometer unless you are changing the total diameter of wheel+tire, and you generally don't ever want to do that. 18 inch wheels have thicker sidewall tires, 19 inch wheels have thinner sidewall tires, resulting in the same (or very nearly the same) total diameter. I change out 19" summers for 18" winters on my BMW, and the only things that need to be "recalibrated" are the TPMS sensors, which is just a setting in the car's computer.
Old Nov 1, 2019 | 07:24 PM
RayLS's Avatar
RayLS
+1 with roger
try this and see how much the difference is.
https://www.tacomaworld.com/tirecalc
Spubgas
RX - 3rd Gen (2010-2015)
Mar 4, 2018 03:05 AM
comotiger
Oct 25, 2016 06:53 AM
Marqevans
40
Jan 15, 2015 03:27 PM
BatmobileX
Oct 1, 2011 01:43 PM
