Transmission going bad?
Old Jul 20, 2019 | 03:54 PM
Beatdemon's Avatar
Beatdemon
Default Transmission going bad?
Since purchasing this 2010 LS460, 3 months ago I've noticed that in low gear the transmission "slips" or at least that's what if feels like. Usually this happens in 2nd gear for me and when I slow down by braking to turn a corner, for example, pressing on the excellorator will give me high RPM's without actually doing anything for a moment and then it engages. It's not a "jerk" motion when it does, but pretty smooth. Is this normal behavior or does this sound like the beginning of a very expensive problem?
Old Jul 20, 2019 | 04:06 PM
john341's Avatar
john341
Sounds normal, lots of Toyota & Lexus have this, where it fells like power is cut when turning hard. You might need to so zero point calibration, which has solved this issue for me in the past. Also change the Trans fluid if the car has more than 50000 miles.
Old Jul 21, 2019 | 01:24 PM
lexus13dan's Avatar
lexus13dan
Normal , Just feels that way
bowen.chau
RX - 1st Gen (1999-2003)
Jun 2, 2013 07:58 PM
KrazeMatik
Jul 17, 2007 09:22 PM
