wow. ok thanks . yea ive learned to take my time this past month. rushing is how i broke my condenser what made you remove the injectors originally before they fell apart ?
I had a valley plate leak. I had to disconnect the injectors from the wire harness to clear up some room. When I tried to reconnect it, the injectors just fell apart. Also, latches on four connectors broke off due to aging plastic.
I have exactly the same problem now! Had the knock sensor issue, decided to replace, disassembled the car today, found the coolant leaks, decided to fix with sealant, started to remove the plate and broke 2 high pressure injectors and 4 connectors🤦
So here is the question : did somebody try to install chinese injectors from eBay?
https://www.ebay.com/itm/363332635300?fits=Model%3ALS460&hash=item5498500aa4:g:W-kAAOSww59gWwTA
So here is the question : did somebody try to install chinese injectors from eBay? https://www.ebay.com/itm/36333263530...kAAOSww59gWwTA
No, I bought low mileage injectors off a parted out GS350, the part number is the same. But the mark on injectors must be the same for the same bank.
