ABS and Brake lights is on
Old Mar 10, 2019 | 06:14 PM
Kee318's Avatar
Kee318
Default ABS and Brake lights is on
I changed the rotors and Brake pads on my 2013 ls460 F sport with crossed drilled and slotted and the ABS and brake lights came on. Anyone went through the same problems?
Old Mar 10, 2019 | 06:27 PM
jdanielca's Avatar
jdanielca
did you do it yourself? just check that all the wires and sensors are in place. lights with no messages?
Old Mar 10, 2019 | 06:40 PM
Kee318's Avatar
Kee318
I did it myself. All sensors and clips are on the brake pads.
There's a message that said brake malfunction and take it to the dealer. I think air is inside the line. My brother accidentally removed the wrong bolt on caliper and Brake fluid came out.
Old Mar 10, 2019 | 07:32 PM
jdanielca's Avatar
jdanielca
try thst if not then clean the wire connections with maf sensor cleaner and reseat everything that’s what I would do, just process of elimination.
I dont know how to bleed brakes manually so can’t help you there I’ve only read about using tech stream
MyLS460
Jan 25, 2024 09:06 PM
patriciam1
Sep 8, 2018 03:35 AM
Ratatat
Aug 17, 2009 09:57 PM
EBMCS03
Suspension and Brakes
35
Jun 7, 2006 09:56 AM
