Cabin Air Filter Question ?
Old Jun 5, 2018 | 01:01 PM
colfax's Avatar
colfax
Default Cabin Air Filter Question ?
Hi everyone!
So, I pulled out the cabin air filter in the glove box, cleaned it and put it back in, and now when I start the car the ventilation system acts confused.
Initially nothing happens, the lights for Auto, etc, do not come on as they did before. Eventually after a minute or so sometimes the AC starts up and other times i have
to go Climate and turn it on manually. At that point everything works normally although now the interior is set for 75 degrees versus it was 70 before I removed the filter.
I am guessing some delicate sensor has been disturbed despite my best effort to carefully refit the black plastic cover plate, I did not bother fitting the "shelf" plate.
Could not fitting the shelf plate have disturbed things? I really do not want the cost and hassle of taking it to a dealer, can someone comment on this?
Old Jun 5, 2018 | 01:32 PM
LatinLS430's Avatar
LatinLS430
It's on the FAQ on here:
https://www.clublexus.com/forums/ls-...er-change.html
Post #3 and #12 on what to do before doing the cabin filter change.
Old Jun 5, 2018 | 01:46 PM
Spudo769's Avatar
Spudo769
When I changed mine the filter wasn't quite seated in the holder correctly. I fixed it and it worked fine after. ALWAYS PUT THE SYSTEM ON RECIRCULATE PRIOR TO ACCESSING SO THE DOOR IS OPEN.
Lutkis
May 27, 2018 11:10 AM
wiliam
Aug 13, 2014 02:19 PM
ohnow
RX - 1st Gen (1999-2003)
Feb 18, 2013 05:41 PM
Lust4Lexus
Jul 15, 2010 08:43 PM
triplecore
Maintenance
Nov 17, 2008 03:58 PM
