I'm looking for a diagram for the 24 pin connector on the back of a ls 2007-2009 instrument cluster (for hybrid more specifically but regular ls460 should be similar). No luck so far looking online, but I'm guessing it should be in the Electrical Wiring Diagram service manual if anyone have that and willing to share. Any help would be much appreciated.
You need to connect 12v into pin 13 and 14 and NEG into pin 18 to power the cluster on. To be safe I put an automotive fuse (10A) on BAT line, 5A on IG and 10A on NEG. Connector is identified as L10 and part number is 90980-12554.
I am trying to see if a 2010-2012 LCD hybrid cluster will work on a 2007 460 . I know that the japan only 2010-2012 LCD cluster 460 specific works on a RHD 2007 LS 460 minus the gear indicator .
