Starting Problem, when Engine at Operating Temperature
Old Oct 31, 2017 | 09:38 PM
LexusOz's Avatar
LexusOz
Default Starting Problem, when Engine at Operating Temperature
Hi All,
Our 2008 LS460 with 90,000 miles (57,000 Klm's) has intermittent starting problem after engine has reached operating temperature.
It will take two or three tries before engine will start. OK from cold start. No error codes.
Any feedback or clues appreciated.
Cheers.
Old Nov 2, 2017 | 08:18 AM
allwheels's Avatar
allwheels
Does it actually crank and not start, or just silence?
Old Nov 4, 2017 | 11:23 PM
LexusOz's Avatar
LexusOz
allwheels,
Engine cranks OK, ......but engine does't fire. Usually engine fire on third attempt, this only happens when engine is at operating temperature.
As indicated earlier engine fires OK from cold start.
Cheers
Old Nov 6, 2017 | 07:28 AM
213374U's Avatar
213374U
Do you ever experience any smoke from the exhaust?
Old Nov 7, 2017 | 12:36 AM
LexusOz's Avatar
LexusOz
Thanks for reply,...no smoke from exhaust.
Engine is cranking OK, Have checked fuel pump,... it's OK. Vehicle traveled 90,000 miles, & engine has original spark plugs.
Also thought as we've been using 95 RON fuel this could be a problem ?..... talking with Lexus Service they advise should be OK, ....although 98 RON preferable.
The only other consideration would be a bad batch of 95 RON fuel ? Now will use only 98 RON fuel to see if that makes a difference.
Cheers
lymlyt
Dec 15, 2016 06:04 PM
Lexus082
Oct 9, 2012 06:35 PM
jewel
Jan 3, 2007 01:38 PM
