change TPMS IDīs on a 2006 LS 460 with Techstream and Mini VCI
Hallo from germany,
I just become exasperated and frustrated. I only need to change the TPMS IDīs of my LS 460 with Techstream and some Mini VCI cables. I can read and erase DTCīs but itīs not possible to change the IDīs or reset the transmission-memory.
I tried to do this with Techstream 8.00.034 and 10.10.018 and Mini VCI cable with firmware 1.4 and 2.04. If I make the cable test with Techstream it shows that the CAN-protocol is ok, but K-Line and L-Line are not supported.
Is the missing K-Line protocol the reason for this trouble?
Is there any LS 460 driver who was able to change this settings with a working techstream and mini vci configuration?
Please no discussion about to go to the dealer shop - I want to change this 4 datafields with 7 digits of my own - I donīt want to be disappropriated by the manufacturer...and I see no reason to by a extrem expensive mongrrose cable with hardware included of 5$...
Thanks a lot
Andreas
Thanks a lot
Andreas
BlazeViper (12-01-21)
Hallo,
if nobody has mini VCI working on an LS 460 - then may be there is a possibility to bypass the tpms system with idīs where it does not search for or any sensors or another hardware trick like it works on older lexus models?
I only want to deactivate it if I canīt change the 4 senor idīs with techstream myself...
many thanks
Andreas
many thanks
Andreas
If you can read the TPMS id. in the ECU, use utility to change it. I can do it on my RX450h without any problem. Just don't hit the reset button under the dash. If you do you'll get yellow warning light. Using utility you have 5 minutes time limit to enter 4 ids. My Techstream version is 12.10. 019.
AndreasMUC (06-05-17)
Hallo,
I donīt think that the techstream is the problem. I can read the idīs - but changing is the typical error.
So the main question is what type of cable do you exactly use? Firmware 2.0.4? What is the result of a cable test? Is k-line or l-line supported? Reseller of this working cable?
Many thanks
Andreas
Many thanks
Andreas
Hallo,
Many thanks
Andreas
Many thanks
Andreas
If you have problem maybe Main Menu is older version. Replace it with newer one. Again Peruse Youtube. I have Autel MS501 as well so I can do it
with it or read ids. with MS501 , use Techstream to register. Or by any chance are you using 64 bit version which is known to be finicky. I use W7 Pro 32 bit
OS. Good luck.
Any update on this? Sorry for reviving an old thread but I just joined the LS460 brotherhood. Ive read that the mini cvi cables wont work for this function? Is this true? I get an error everytine I go in to register the Id numbers of the new sensors. Can anyone confirm that the carista app can do this?
To save potential headaches; thanks to MX73's post, I bought this cable and finally got my sensors registered. It simply worked perfectly, while the 1.4.x cable I got from AliExpress earlier just wouldn't do it regardless of installed Techstream version.
Hi JMLS, I've got a 2007 LS460 (US version but was imported to Europe in 2008) and I have Carista app and the OBDC dongle but every time i add the new TPMS IDs it only works for 30 km or so and then the TPMS warning light comes on telling me i need dealer assistance. Did you get Carista to fix things permanently? Thanks Stu
lexus600hl
07-27-14 12:36 AM
