2013 Lexus LS 460 - Lowered with Skipper Lowering Link
Old 05-25-17, 11:05 PM
VancityLS
VancityLS's Avatar
Default 2013 Lexus LS 460 - Lowered with Skipper Lowering Link
I've recently installed the Skipper Lowering Link to my 2013 LS 460 AWD, non-LWB. I know most guys drop their LS with either aftermarket air suspension, or the DataSystem Module on OEM bags. Lowering links are another common method (also, an affordable way to lower the vehicle), however I personally did not find much threads on DIY installs or pictures of OEM suspension with the links.
Personally, I'm more budget conscious when it comes to spending money on the vehicle. Therefore I went with the cheapest way to lower the car, just for aesthetic purposes.
I thought I'd just share few pictures of my car, and share some of the experiences I've had after driving the vehicle for about 3 weeks now with lowering links.
The Skipper Lowering Link drops the front 1.3" and the rear 1.5". It is pretty much a plug and play sorta deal, with proper tools and equipment it should be done within a couple of hours at most. Wheel alignment should be done professionally.
ISSUES:
The LS' OEM air suspension automatically lowers the vehicle after 65 miles per hour or 90 km/h. I have noticed that while I am cruising on the highway, if I let off the gas after 65mph or 90kmh the car has a settle vibration. If I apply gas, the vibration goes away. Going downhill, I tested the vehicle by putting it in neutral and coasted past 65mph and the car did not vibrate.
The car has been to an alignment shop and the rear tow was off, and fixed. However the vibration while coasting on Drive after 65mpg is still there. Anyone know why that might be?
Greatly appreciated if there are any feedbacks/suggestions on this topic.
Anyways, here are some pictures of the vehicle after the install Enjoy!
P.S. I am aware of the silly OEM 19"s, working on saving up towards a new set up
Driver Rear
Driver Front - Close Up
Driver Rear - Close Up
Passenger Side Overview
Driver Rear - Glamour Shot
Passenger Side - Glamour Shot
Passenger Side - Overview
Random Night Shot 1
Random Night Shot 2
Random Night Shot 3
The following 2 users liked this post by VancityLS:
Boomin (01-04-21), Streetcar1 (05-26-17)
Old 05-26-17, 01:30 AM
1WILLY1
1WILLY1's Avatar
that looks really great
You lowered the car quite a bit
Can you give us some details on the installation?
Did you do it yourself or have a shop do it for you ?
Old 05-26-17, 06:17 AM
qtrung909
qtrung909's Avatar
Looks good, I may try it out as well.
Those puddle lights look great as well, still waiting on my guy to do mine.
Old 05-26-17, 01:12 PM
VancityLS
VancityLS's Avatar
Thanks you!
It was done by a friend of mine who had proper jack + jack stands. Unfortunately I do not have pictures of the install itself..
Basically, we took off the wheels and lifted up the car.
The OEM links will then be in plain sight.
The Skipper Lowering Links came adjusted to the lowest right height, so there were no adjustments made there.
It was then just removing the linkages, and replacing them with the new ones.
Old 05-26-17, 01:15 PM
VancityLS
VancityLS's Avatar
Definitely a good bang for the buck IMO, it does not benefit from any handling performance etc but that's not what the LS is for anyways
And yes the puddle lights do add another great aesthetic touch to the vehicle.
I had mine done at a local shop that specializes in wiring and audio work. They did have a bit of trouble drilling holes and feeding the wires through to the fuse.
Side skirts are usually hollow but for the LS they have a metal frame underneath, so they drilled extra holes for each LED module and its wiring.
Old 05-26-17, 01:24 PM
VanCityLS4
VanCityLS4's Avatar
What's the minimum drop from these links?
Old 05-26-17, 01:31 PM
VancityLS
VancityLS's Avatar
Good question
It just said 30mm drop for front links and 40mm drop for the rear links. I never looked at the minimum drop unfortunately.. Sorry mate.
Old 05-26-17, 04:08 PM
1WILLY1
1WILLY1's Avatar
Originally Posted by VancityLS
Thanks you!
Thanks man
would u be able to find out if he did it with the car on or off?
Some say the car needs to be running but it doesn't make sense to me
Thanks
Old 05-26-17, 10:56 PM
Streetcar1
Streetcar1's Avatar
Awesome information. Any idea how many inches it drops at 65? I'm betting it's going to low throwing the camber off . You might need to raise it 1/2 inch or whatever the amount that it lowers at 65? Do you order these preset with the amount of drop you want and from where ?
Old 05-31-17, 11:45 AM
Streetcar1
Streetcar1's Avatar
How is the ride and if you use high height button would it be factory height? Also does the front and rear sit level and where is the best place to order ? Vendor on here ?
Old 06-23-18, 04:14 PM
William N.
William N.'s Avatar
I have a 2013 LS460 and wanted to know are the lowering links for the 2008-2012 the same as the 2013?
Old 06-23-18, 06:29 PM
k311in
k311in's Avatar
You can actually lower the car without buying these links. The stock links on the car are already adjustable
Old 06-23-18, 07:34 PM
Caflashbob
Caflashbob's Avatar
You may have altered the driveshaft angles enough to show an imbalance. I have seen posts somewhere about this. Raise it back up to see or live with it and possible driveline work later.l.
Old 06-23-18, 09:36 PM
William N.
William N.'s Avatar
Thank you for the info!! Appreciate it!
Old 12-21-18, 08:08 PM
Markcma3
Markcma3's Avatar
Regarding the stock links, is there any info that you can share on DIY? Any info would be appreciated, video, pdf anything. Thanks!
Quick Reply: 2013 Lexus LS 460 - Lowered with Skipper Lowering Link
