Question On Control Arms
Old May 11, 2017 | 10:26 AM
ohionick's Avatar
ohionick
Default Question On Control Arms
Hello fellow CLites, long time reader but have not had many posts. I have a 2010 LS 460 AWD that I purchased a few months ago. I was doing the first oil change this weekend, thanks for the DIY writeups it made finding the oil filter so much easier with all the plastic on the underbody. Anyways I was checking the control arms and while they appear to be in good shape I know they will need replacing eventually. My question is when I looked at all the sites like rockauto, amazon, ebay and a few others the only parts I could find were for RWD, I wanted to know are these parts interchangable with the AWD model or am I stuck with Lexus OEM parts. Any responses will be appreciated please and thanks!
Old May 11, 2017 | 01:27 PM
anthony1's Avatar
anthony1
Try looking up parts here. http://www.*******.com/parts/q_U_201...~460L_all.html
I use it for my 4runner and GS300 all the time.
The VIN reference is kinda confusing...
Old May 11, 2017 | 01:32 PM
anthony1's Avatar
anthony1
Btw, if you sign up, you can see the diagrams too.
Old May 11, 2017 | 03:25 PM
ohionick's Avatar
ohionick
Default the link is not showing
Anthony1 can you pm me the link as the link is not showing.
Old May 11, 2017 | 03:36 PM
anthony1's Avatar
anthony1
t o y o d i y then period com
Old May 12, 2017 | 12:10 PM
213374U's Avatar
213374U
Also have a 2010 AWD, here's what I found:
48710A ARM ASSY, REAR SUSPENSION, NO.1 RH 48710-500801 $142.77
48720A ARM ASSY, REAR SUSPENSION, NO.1 LH 48710-500801 $142.77
48730F ARM ASSY, REAR SUSPENSION, NO.2 RH 48730-501111 $375.01
48740F ARM ASSY, REAR SUSPENSION, NO.2 LH 48730-501111 $375.01
48770A ARM ASSY, UPPER CONTROL, REAR RH 48710-50100 NO.1 $130.47 48770-50060 NO.2 $515.05
48790 ARM ASSY, UPPER CONTROL, REAR LH 48710-50100 NO.1 $130.47 48790-50080 NO.2 $515.05
48620 ARM ASSY, FRONT SUSPENSION, LOWER RH 48620-500801 $285.22
48623 ARM, FRONT SUSPENSION, LOWER NO.2 RH 48660-590151 $219.11
48624 ARM, FRONT SUSPENSION, LOWER NO.2 LH 48670-590151 $219.11
48640 ARM ASSY, FRONT SUSPENSION LOWER, LH 48640-500801 $285.22
48630 ARM ASSY, FRONT SUSPENSION, UPPER LH Not applicable
48610 ARM ASSY, FRONT SUSPENSION UPPER, RH Not applicable
Old May 12, 2017 | 05:48 PM
wakebord99's Avatar
wakebord99
I've spent months searching for quality aftermarket control arms.. long story short they don't exist.
we are stuck with oem replacements.
213374U
Oct 12, 2023 04:38 PM
vmdw1980
Mar 30, 2018 10:40 AM
ohionick
Jul 14, 2017 09:42 AM
GSRSRT
Sep 22, 2010 01:31 PM
