New Battery
Actually I've been using discount code TRT30 for years and you get 30% or up to $50 off for online orders. Just a tip, if you order more than one item and one of the items gets you the max discount of $50 just order the items separately so you get the max discount on all your items. For example, if you order 2 items, one for $200 and one for $50, order them separately so you get $50 off on the first item and 30% or $15 off on the second item. If you order them together the most you'll get discounted is $50 instead of $65.
side note to all the parking lot pimps... a gallon of gas is only $2.... please run the engine, it will save your amps an charging system.. a few gallons of gas is much cheaper than buying a new batt.. or new amps.. fyi amps get hot due to lack of voltage!!! also make sure u ALWAYS USE 100% COPPER WIRE ONLY!!!!!!! (companies are now selling CCA copper clad aluminum DON'T USE THIS)
I think we need to make it clear to those who might not understand, that the Optima Red Top and Yellow Top batteries are AGM (absorbent glass mat) batteries.
Our cars, the LS460s, are designed and engineered to use flooded-cell starter batteries. That doesn't mean that you can't use AGM batteries and for some owners they may be very desirable for special operating situations but without some clearance from Lexus and the battery manufacturers we don't know if this is a good idea. However, for most of us the flooded-cell batteries provide very satisfactory results as to cost, reliability and durability.
High quality replacement flooded-cell batteries from manufacturers such as Interstate, Diehard, Maxx, and others are readily available from a wide variety of suppliers.
The AGM batteries have some very desirable characteristics and they may be the auto batteries of the future. I expect that the flooded-cell batteries will continue to be the starter batteries in gasoline powered cars for several more years.
Cars are designed for 12 volts. Sometimes a yahoo/Google search before posting can save a lot of back and forth. Now maybe Optima Yellow from the days of old was one thing, but times have changed and so has the objective of the YellowTop.
Everything about idling a car is bad news for the car itself, your pocket, and the environment. Again, this is such old news that unless u just stepped out of 1985 it's rarely debated
YELLOWTOP® BATTERIES
The YELLOWTOP high-performance AGM battery is one of the few true dual-purpose automotive batteries available. With premium cranking power and impressive cycling capability, this heavy-duty battery is also perfect for modern accessory-loaded vehicles. Low internal resistance also provides more consistent power output and faster recharges.
Optimabatteries.com
http://www.afdc.energy.gov/uploads/publication/idling_personal_vehicles.pdf
Optimabatteries.com
As I stated in another thread, Optima is no longer a reliable option since moving their plant to Mexico. There are TONS of posts and review/reports of these batteries failing early. They used to be a top-tier battery. Odyssey is still made in the US and is apparently a better option.
Fair enough. My AC Delco Professional has 3.5 years (42 months) replacement and then pro-rated for 84 months. 100 bucks on sale. I have no personal experience with Optima, I've just been reading a lot about failures with Optimas over the last 3 years or so. If you Google "Optima Problems" it seems that it's rampant. Again, the consensus being the move to Mexico.
just a heads up. the optima's are failing due to lack of charging.. every car I own has red tops. a Nissan altima coupe, my fj cruiser (the battery I took from my dead xterra....head gasket) that batt is 6yrs old Zero issues, an my 460 (which I have 2 both are 2yrs old.) but the 2nd is for audio only an is isolated when the engine is off.. so the main starting batt a red.. sits for weeks without charging an starts up EVERYTIME! I seriously suggest.. that if u do buy optima's get reds.. unless u plan on taking a seriously long drive to recharge your yellows. yes fluid filled batts are the norm from the manufacturer because they are cheaper.. pure an simple.. the Ls has tons of tech to be sure.. but at the end of the day it's a car... an electrical circuits are simple in nature.. they only get complex as they multiply..
lastly the optima's internal resistance is 1/4 that of a fluid filled batt which means less of a strain on the alternator to charge an less demand on the charging system means more power to the rest of the vehicle. remember once the car starts 100% of the power comes from the alternator. .,now if the draw on the alternator exceeds it's output.. then an only then does reserve power get drawn from the battery.. they battery also serves as a voltage stabilizer for the alternator (as it states alternating current)..
unlike fluid filled batts optima's can withstand extreme heat an cold whIle keeping their strength.. which is why they are the main batts used in Motorsports ,power sports racing.. so if professional drivers an race teams who depend on reliability. so as a daily driver...it just makes sense.. but do as u will.. all I'll say is when we have other dead batts everyone knows to call me because my optima has jump them all..
- Deep-cycle and cranking power
- Faster recharging
- Optimal starting power
- Heavy-duty battery that functions well as a tractor battery or forklift battery
+1 on Shibumi1's post, the Red is the Optima to get if for the car itself. By all means get the Yellow if that is your preference
FWIW, if you go to the Optima website, it will bring back the Red when you use the car application guide
A wheel is not a battery, but the same thinking applies. My car would look better with plus sized wheels, and it would look better if I'm not getting a jumpstart.
http://www.myrideisme.com/Blog/optima-battery-red-or-yellow-top/
SC34U..it has both top an side mount terminals. .actually all my batts are SC34U's
now my oem terminals have been swapped for different ones (but that was done last yr b4 H.I.N.) prior to that I used my oem terminals the just needed to be "slightly" bent to fit... an I do mean slightly.. here are some pics.. there maybe greater details in my build thread
