Will these wheels fit on my 13 LS 460 AWD base?
Old 03-03-16, 05:00 PM
Kuhan
Kuhan's Avatar
Default Will these wheels fit on my 13 LS 460 AWD base?
So I still have my old BMW M5 wheels and tires, and I wanted to know if the front wheels are too aggressive or not. The bolt pattern is 5 x 120 same as the LS.
Front: 19 x 8.5 +12 with 255/40
Rear: 19 x 9.5 +28 with 285/35
Will this setup fit on stock suspension? I think the rear would be ok but the front might be too aggressive?
Old 03-03-16, 06:08 PM
Rhambler
Rhambler's Avatar
http://www.willtheyfit.com
Old 03-03-16, 08:38 PM
Kuhan
Kuhan's Avatar
Thanks for your help!
Old 03-06-16, 03:55 PM
lbintab
lbintab's Avatar
You own the 2013 LS already? If so why not just try to fit them if you also already have the wheels and tires. You'll have the for sure answer.
Old 03-07-16, 11:45 AM
GR6RR
GR6RR's Avatar
I bought my wheels from an ex-bmw owner. Wheels will fit for the most part. You may need to get hub rings. BMW has big brakes as well, so that part shouldn't be a problem.
as said above, throw them on. The worst that could happen is you have to take them off...
Specs i bought:
20x9 +15
20x10.5 +15
The fronts after lowering them seem a little tucked, may add a small spacer to help with fitment later on down the road.
The rears are where I want them to be, rim flush with fender with a very mild stretch on the tires.
Old 03-07-16, 12:49 PM
Dr. Jekyll
Dr. Jekyll's Avatar
Post pics when yo get them on too, we'd all love to see them!
Old 03-10-16, 05:42 PM
Kuhan
Kuhan's Avatar
Thanks for the help. I decided not to put them on because of the offsets are a bit aggressive plus the tires are much bigger. I sold them to a friend who has a M5 also.
But ghetto pics. :
Old 03-11-16, 07:51 AM
Rhambler
Rhambler's Avatar
Yeah, I think you made the right choice. If you want to upsize, there are many good options out there that would fit much more naturally.
Pnice
07-23-18 02:35 PM
LexusFan09
03-12-12 12:36 PM
Boger74
05-13-11 08:18 AM
jmbaker3
11-24-08 05:19 PM
93LS
02-17-05 11:48 PM
Quick Reply: Will these wheels fit on my 13 LS 460 AWD base?
