tanabe nf210 springs QUESTION HELP
Old Jan 23, 2016 | 02:01 AM
fatalexx's Avatar
fatalexx
Default tanabe nf210 springs QUESTION HELP
so I have a 2010 ls460 and looking for some lowering spring. I was wondering will the tanabe nf210 fit ? because all the one I found is for 2007-2008. isn't 07-12 have the same body? please help.
Old Jan 25, 2016 | 09:34 AM
GR6RR's Avatar
GR6RR
Not sure if it'll fit, but it should. And if you need a set, I have a used set for sale. located in socal San Gabriel Valley area.
The only difference I have read is the L model, which most have reported sits lower than non L model, when lowered on Tanabe springs.
Old Jan 25, 2016 | 02:14 PM
CJITTY's Avatar
CJITTY
I had a few minutes so here is what I found via Pembroke Pines Trademotion Parts website. Looks like you may be in luck based on what I found. Assuming you have a SWB with RWD, the OEM springs have the same exact part number on the 2007's and 2010's.
LS460 SWB/RWD Front Spring Part #
2007 Model - 4813150250
2010 Model - 4813150250
LS460 SWB/RWD Rear Spring Part #
2007 - 4823150320
2010 - 4823150320
So, if the oem spring part #s are the same for the 2007 and 2010 model LS's, one would have to assume that you should be good to if you have short wheel base with non all wheel drive 2010 LS.
Source https://www.trademotion.com/parts/20...iagram=8932550
Old Jan 26, 2016 | 10:04 AM
fatalexx's Avatar
fatalexx
Cool thank you so much for this info !!
pmlexus
Mar 10, 2016 11:10 PM
20GS300
May 9, 2013 04:55 AM
Tanabe USA
Jun 13, 2008 04:17 PM
