Check Tire Pressure System
Old Jan 17, 2016 | 10:49 PM
LS2k's Avatar
LS2k
Originally Posted by satiger
Denso OEM TPMS at Amazon for $36.50 (sold by Amazon)
Amazon.com: Denso 550-0103 TPMS Sensor: Automotive
For 2007-2012 models Toyota OEM part no : 42607-33021
Denso part no: 550-0103
Perfect, thanks for all the feedback everyone!
Old Jan 21, 2016 | 04:29 PM
LS2k's Avatar
LS2k
After reseting the error with carista, a week later and like dpresco mentioned above, my dashboard now shows all five tires pressure correctly once again for the time being.
Old Jan 22, 2016 | 07:42 PM
CJITTY's Avatar
CJITTY
I got 4 slightly used pmv-107j sensor on ebay for less than $75 shipped..perfect for my 22" wheels..work great
Old Jan 24, 2016 | 08:48 AM
LS2k's Avatar
LS2k
Thanks for sharing, so something like this will work on an '07 ? http://m.ebay.com/itm/Complete-Set-of-4-OEM-Toyota-Lexus-TPMS-Tire-Pressure-Sensors-Service-Kits-107J-/191776441077?nav=SEARCH
Old Feb 20, 2024 | 04:39 AM
Doublegrants18th's Avatar
Doublegrants18th
Originally Posted by LS2k
Thanks, so the way to go is to replace all 5 of the tpms sensors not just the batteries? If i get them from fleabay, I presume it's going to be difficult to find an tire place that will install the new tpms sensors for you since you didn't buy those from them...
Meanwhile, is there a way to disable that warning on the console?
That's what's I'm doing. The Toyota/Lexus ones from FleaBay lmao
Old Feb 24, 2024 | 05:14 PM
Lance460's Avatar
Lance460
Walmart will replace it for $28.88 including the sensor.
Not a bad deal.
Old May 21, 2026 | 02:15 PM
raydsimons's Avatar
raydsimons
5th Gear
Default TPMS Replacement\Programming
[QUOTE=Doublebase;9324919]You can take it just about anywhere and they'll be able to read your sensors and check for response, if the sensor doesn't respond to the TPMS tool...the battery in the sensor is dead. The sensors generally last 7 years.
Most after market sensors are between $35-$60 dollars a piece, an independent shop would probably charge you $350 for four...only problem is your car takes five (spare tire). You could just replace one, but you may get a better value if you replace them all.
I purchased 4 sensors for my 2007 Lexus LS460L from Amazon for $32.59. I took my car to Economy Tires installed them for $60 and Tire Plus programmed the whole set for $20.
mr29rose
Jul 24, 2021 04:40 AM
sprtdsgnGS
Jul 22, 2017 09:44 PM
jud149
Apr 9, 2017 07:06 PM
nosurprise
Dec 30, 2015 01:24 PM
danielxxxx
RX - 3rd Gen (2010-2015)
Nov 21, 2015 02:32 PM
