I might stop doing extended oil change intervals
#91
Well I'm now 3,000 miles into a 5w30 weight synthetic oil change. I have not lost a drop of oil yet, but I really wasn't expecting much anyway. My gas mileage has improved - compared to the first three weeks into the oil change - I'm now back to averaging 26.2 mpg. And I swear to you that I couldn't achieve that mileage during the initial part of going to 5w30...might the oil have sheared just a little bit?
I'll check back in when I reach 5,000 miles.
One thing I'll probably do if this proves successful, is go to a higher quality brand of oil. Right now I'm using a Napa house brand full synthetic and it's basically rebadged Valvoline, which is very light on additives...virtually no moly.
#93
The 5w30 gets better with time. I almost pulled my 0w30 at about 2,500, but it holds up pretty well too. The 5w30 has given me better results (i.e. no "mystery" oil loss and more mpg's)
#94
Well that didn't work, I've reached 5,000 miles and I ended up adding a quart between 4,000-5,000 miles. So much for the 5w30 being thicker, shearing less and consuming less...it didn't make a single difference.
Maybe it was because I used a cheap house brand synthetic that had very little additives? I don't know? And really it's not something I'm worried about, using a quart of oil in 5,000 miles is not exactly something to get depressed about - if this was a BMW or an Audi, it would have used 5 quarts.
I just bought a bunch of Mobil 1 (it was on sale and with their rebate program they have going on right now I ended up paying $2 a quart). So that will be going in the car next. Mobil 1 has a pretty robust additive pack with a good amount of moly and boron (both of which was missing from the last product I used). Maybe that will help? I guess I really do mind either way, the car runs great and I certainly can live with a loss of a quart in 5,000 miles.
I'm going to stick with the heavier weight oil for a while anyway...my gas mileage stayed consistent with what I got when I was using the 0w20...plus the weather is getting warmer around here now.
#95
#96
No problem and like you I really don't think anything of using a quart in 5,000 miles, especially from a car that now has 126,000 miles on it. And like I said, I wonder if I had been using a better oil things could have been different? Let me know how it works out for you with the Castrol.
#97
with the 1/2/3uz motors, you can go to 10k intervals with synthetic, and you wont burn a drop and the oil will still look good, an oil analysis was done and proved right.
#98
Yeah I always liked the smoothness of those engines, but I don't recall going 10k miles on oil changes anywhere near the norm of what people did with those engines. People that drove around with the 1 and 2 uz's probably never even considered going that far back then, it was unheard of/blasphemy. CAFE regulations changed the OCI in the industry. I see a few people with the 3uz extending their oil changes out that far, but not a ton.
#99
I've had several oil analysis' done on my oils - one of them at 10k miles, and they always returned with a clean bill of health. That said, the oil is going somewhere.....and it's not leaking.
#102
So the 4.6L V8 engine is like a common household dryer, eats up socks mysteriously every now and then?
#103
Yeah once I start using a higher quality oil, that's the number I usually shoot for. I'm no longer concerned with losing a quart of oil along the way...my experiment with a shorter oil change interval and heavier weight oil didn't really change much. I feel pretty comfortable going 7,500 with a quality synthetic.
