Code p2240
Old Nov 9, 2015 | 11:01 AM
Bluv's Avatar
Bluv
Default Code p2240
Was wondering if anyone know what's best to do, say it's 02 sensor bank 1 any help appreciated, and thanks in advance
Old Nov 9, 2015 | 11:43 AM
chpten8's Avatar
chpten8
If your scanner can read the monitors you can graph the o2 sensors up and downstream and more or less get an area of where the fault is, O2 sensors read oxygen levels and compensate for the fault by adjusting fuel/air ratios. Faulty ground, vacuum lines, clogged injectors, or the sensor itself can all contribute to a faulty O2 sensor, although throwing a new one on will 75% of time fix it, there are other times that things maybe wrong and the sensor is simply advising you.
Old Nov 9, 2015 | 01:28 PM
Doublebase's Avatar
Doublebase
Truthfully it's probably just the sensor, if it wasn't there would be other codes to go along with it. You can do a visual inspection of the wires, this is the time of year mice love to eat wires in an engine compartment. It could be the heater circuit (bad sensor). If it's not the sensor it could be a million other things, but like I said, most of them will throw other codes.
MsbTTSupra
Feb 21, 2020 07:27 PM
Dan040286
Aug 17, 2019 03:32 PM
techiedude
May 2, 2012 06:57 PM
12340987
Jun 2, 2009 07:26 PM
BklynJay
Performance
Nov 19, 2006 10:39 AM
